Configures the size of local notification cache.
size | Specifies the size of the local notification cache. |
slot | Specifies the slot to be used. |
all | Specifies all IP addresses, or all IP addresses in a particular state. |
The default is 1000 events.
This command configures the size of local notification cache. Cached events are stored in local memory. The range is between 1 and 1000 events per second. If the cache is full, newer events replace older events.
This command was first available in ExtremeXOS 12.0.
